[GRASS5] d.site.labels and d.sites.label
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 2 04:57:47 EDT 2000
Hi Andreas,
On Mon, May 01, 2000 at 05:12:54PM +0200, Andreas Lange wrote:
> Hi Markus, Hi Grass-developers,
> i need some input on how to create a consistent user interface for the
> sites programs.
> As the possible field components (zero or one category value, many
> floating point values, many string attributes) and their combination can
> not be put on one label the user IMHO should be able to select which
> parts of the sites entry should be used by d.sites.label.
If adding this useful selection feature to d.site.labels please
consider if you could include it into
s.to.rast and
s.to.vect
too (as it is the same problem).
Thanks in advance
Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1476
max: 0
