[GRASS5] Old compile method
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 30 05:27:43 EST 2000
Hi Justin,
On Thu, Nov 30, 2000 at 03:20:53PM +0700, Justin Hickey wrote:
> Hello all
> I am looking into removing the old install method from the CVS tree as
> well as from the INSTALL file. I was wondering if anyone is still using
> the old compile method for compiling grass? Or is everyone using the
> "configure - make install" method?
> Please let me know if you are using the old method.
>From my side: please remove the old stuff. Nobody *should* use an old
method, if an improved modern method is there. GRASS shouldn't be
a museum :-)
Yours
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
