[GRASS5] New initialization code
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Nov 30 04:03:18 EST 2000
Hi Robert
Robert Lagacé wrote:
> We need to know that, on all SVR4 systems such as HP-UX 10 and 11, all
> non OS software should be installed under /opt/.  So, Grass would be
> in /opt/grass/bin/ and appropriate directories under /opt/grass/.
> System admin is simplified because everything is under one directory.
> I will test the new configure under HP-UX when I will have time (in
> two weeks).
Hmm. Another "standard" local program install directory. Arrrgh. Well,
the only thing I can think of is that we use some way in configure.in to
detect HP-UX. What is the output of "uname -s" for HP's? If we can't get
it installed in /opt by default, then you will have to use the --prefix
and --bindir options for configure.
By the way, what is the bin directory that appears in user's PATH's,
/opt/bin/?
Thanks in advance for the test!!
PS Cheers to a fellow Canadian! :)
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
