[GRASS5] Configure Broken in CVS
(was: MATHLIB not found link error)
Markus Neteler
neteler at geog.uni-hannover.de
Wed Nov 29 08:13:30 EST 2000
On Wed, Nov 29, 2000 at 11:58:20AM +0000, Michel Wurtz wrote:
> Markus Neteler wrote:
> > On Wed, Nov 29, 2000 at 06:54:13AM -0500, Tim Cera wrote:
> > > With the CVS checkout on Tuesday night, './configure', 'make install',
> > > received an error for just about every link. "Cannot find @MATHLIB@
> > > .." or something to that effect. The command line shows @MATHLIB@
> > > instead of "-lm", or whatever my distribution needs. Suse 6.4. Sorry
> > > that I don't have time to track down solution.
> I have the save reaction on a Debian 2.2 Linux
> You should also have USE_OPENGL=@USE_OPENGL@
> in the main Makefile...
> > this was reported for several platforms. It would be a help
> > if you could copy-paste this part of configure messages:
> > checking for xdrmem_create in -lsun... (cached) no
> > checking for xdrmem_create in -lnsl... (cached) yes
> > checking for xdrmem_create in -lc... (cached) yes
> > checking for deflate in -lz... (cached) yes
> > checking for atan in -lc... (cached) no
> > checking for atan in -lm... (cached) yes
> These lines don't even appear in the output of configure !
> In fact configure is broken. I removed configure and
> ran autoconf (using configure.in from distrib).
> Now everything just works OK !
Michel,
this was an excerpt from *new* configure. I was thinking you are
already using the improvements from Eric. Well, now it's clear!
Cheers
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
