[GRASS5] New initialization code
Markus Neteler neteler at geog.uni-hannover.de
Tue Nov 28 12:48:01 EST 2000
On Tue, Nov 28, 2000 at 02:19:55PM +0100, Andreas Lange wrote:
> Hi Justin,
> i can not test this right now.
> But i think that the grass5 -text will work. But it will further confuse
> users if they just issue grass5 and they get windows with no useful
> information popping up.
Hi Andreas,
I agree - so a test for wish must be there. If it fails, the init
routine must fall back to text. Then nothing bad could happen.
> We must change all the documentation, so that i think that it will be
> simpler to keep the default as it is. In my eyes grass5 -tclwhatever for
> the new and grass5 (=grass5 -text) for the old behaviour will be simpler
> to recognize/learn.
Well, to attract more users, some GUI is required. I am working
command line (nearly) only, but I am teaching students (so I get
impressions about the average user's expectations). See my
other mail as well.
Changing docs: I can't see that this is a big task. The new graphical
login is not that difficult to understand, but the text entry is for
newbies. My experience so far...
> On my linux installation i get the same error message that Eric
> describes. See attached error.txt.
> Error in startup script: couldn't read file "wish8.0": no such file or directory
Can we agree to program "wish" everywhere. Seems to be existing on
SuSe platforms. Others? Then we avoid annoying this version checking.
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
