[GRASS5] configure.in Wants testers...
Justin Hickey jhickey at hpcc.nectec.or.th
Tue Nov 28 05:56:17 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> What I gleaned from the AutoConf docs I have, is that $top_srcdir
> should be used to reference the TOP src directory.  Apparently it's
> not being expanded, so I'll look into a way to make it be forcably
> expanded.
I played around a bit with SRCDIR and $top_srcdir and it appears that
$top_srcdir for some reason is not being preset to anything since the
test for it fails. However, the good news is that I found a solution for
setting SRCDIR for my machine. Instead of using
SRCDIR=$(pwd)
I used the following:
SRCDIR=`pwd`
This will properly define the SRCDIR variable (an expanded path) in my
Makefile. However, the question is whether this works on other
platforms. I think it should since it is basic shell syntax. What do you
think?
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
