[GRASS5] configure.in Wants testers...
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 04:26:38 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> What I gleaned from the AutoConf docs I have, is that $top_srcdir
> should be used to reference the TOP src directory. Apparently it's
> not being expanded, so I'll look into a way to make it be forcably
> expanded.
> I guess I could just make the configure.in always use $(pwd). That
> should always work (right???).
I would have thought so but that is the current problem on my system.
The @SRCDIR@ variable is substituted with $(pwd) without executing the
pwd command. So it is now a make variable called pwd which is empty.
However, I did notice in that section of configure.in, that there are
brace brackets {} used for $top_srcdir but parenthesis () used for $pwd.
Could that be the problem? Just a wild guess.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
