[GRASS5] configure.in Wants testers...
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 03:34:39 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> On Mon, Nov 27, 2000 at 11:43:05AM +0000, Markus Neteler wrote:
> > > You will notice that SRC variable is empty, thus causing paths for
> > > things in the grass source tree to bigin with /. Checking the
> > > Makefile indicates that SRCDIR=$(pwd) which in this case is empty.
> > > I don't know if this is only happening on SGI's or not. Markus,
> > > did you try a make
> > > install on Linux?
> > On Linkx it runs well with new configure (except TCLTK):
> > Makefile
> > SRCDIR= /home/neteler/ggg
> > It is set properly.
> > In configure.in it is aroung line 417:
> > SRCDIR=$(pwd)
> Yes, I added that. I thought that was supposed to be the "portable"
> way to run 'pwd', but apparently it isn't. `pwd` is supposed to be
> bad, but I don't know why. I'll take a look again.
Since my system seems to be causing the problem I did some poking around
and I may be totally off-base here since my knowledge of autoconf is
very minimal.
What I found was that the @srcdir@ variable (note the lower case) is
preset by autoconf. I commented out the lines concerning the definition
of SRCDIR in configure.in and changed the substitution string in
Makefile.in to lower case. I then ran make distclean, ran autoconf, then
ran configure and the substitution in Makefile turned out to be "." (a
single dot - current directory).
Does this value make sense for our purposes? On my machine, when I ran
make install, it solved the earlier problems, however, in
src/CMD/generic/GISGEN.sh, there is a "cd /tmp" command at the top which
screws up the $GMAKE variable, since it is set to ./src/CMD/gmake5.0
(which does not exist in /tmp).
So, it appears that the . definition would work if all our scripts were
written to take this into account. Does anybody know what kind of effort
this would be (perhaps this is a minimal change)? Does the @srcdir@ get
substituted with a dot on other systems? Or am I way off base and this
is just a looney idea which somebody else has already looked into?
Any comments would be greatly appreciated. Thanks.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
