[GRASS5] configure.in Wants testers...
Markus Neteler neteler at geog.uni-hannover.de
Mon Nov 27 12:27:58 EST 2000
On Mon, Nov 27, 2000 at 05:31:42PM +0100, Bernhard Reiter wrote:
> On Thu, Nov 23, 2000 at 09:32:28PM -0800, Eric G . Miller wrote:
> > I think I've implemented all of the checks in the hacked configure
> > script in configure.in.  So, now I need others to test it and give me
> > problem reports.
> I am using current CVS version of configure.in rev 1.16.
> My problem ist that there is no way to disable opengl.
Generally I suggest to have as most as possible *active*, but
disabling should be possible not to crash the configure.
> There also should be an option to disable the SGI mesa widgets and
> the corrersponding commands, because not everybody has the mesa build by
> themself.
Well, at least SuSe7.0-Mesa contains the SGI mesa widgets :-)
I can't remember that I had to compile myself. Should a be
*disable* option as well.
Just my 0.02 Euro
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
