[GRASS5] configure.in Wants testers...
Eric G . Miller
egm2 at jps.net
Mon Nov 27 21:58:21 EST 2000
On Mon, Nov 27, 2000 at 11:43:05AM +0000, Markus Neteler wrote:
> > You will notice that SRC variable is empty, thus causing paths for
> > things in the grass source tree to bigin with /. Checking the Makefile
> > indicates that SRCDIR=$(pwd) which in this case is empty. I don't know
> > if this is only happening on SGI's or not. Markus, did you try a make
> > install on Linux?
> On Linkx it runs well with new configure (except TCLTK):
> Makefile
> SRCDIR= /home/neteler/ggg
> It is set properly.
> In configure.in it is aroung line 417:
> SRCDIR=$(pwd)
Yes, I added that. I thought that was supposed to be the "portable" way
to run 'pwd', but apparently it isn't. `pwd` is supposed to be bad, but
I don't know why. I'll take a look again.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
