[GRASSLIST:1192] Re: [GRASS5] Re: notation standardisation
GRASS grass at geni.knu.ac.kr
Sun Nov 26 22:52:19 EST 2000
> From owner-GRASSLIST at baylor.edu Mon Nov 27 09:38:39 2000
> On Sun, Nov 26, 2000 at 09:00:40PM +0100, Morten Hulden wrote:
> > On Sun, 26 Nov 2000, seppo kaitala wrote:
> > > Would it be good if the notation would be same for the same kind of
> > > consepts.
> > > For instance in commands
> > > v.proj map=name [out=name] inloc=name [dbase=name] [set=name]
> > > r.proj input=name location=name [output=name] [mapset=name][dbase=name]
> > > [method=name] [res=value]
> > The case r.proj/v.proj should be easy to fix, but which one is
> > preferrable? Also, s.proj's syntax is similar to r.proj's. But I think I
> > at least would prefer v.proj's shorter. Others?
> Well, I thought we agreed a while back to use input/output whenever it
> was appropriate. IMHO, a "map" is a complete printed or digital thing,
> with scales, north arrows, grid marks, legends, etc... I think "inloc"
> should be "location" as well (it's only 3 more characters).
I agree, I think it would be better to use full description name.
"inloc" is somewhat nonintuitive.
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
