[GRASS5] Re: some bugs
GRASS grass at geni.knu.ac.kr
Sun Nov 26 14:53:51 EST 2000
> > From neteler at geog.uni-hannover.de Mon Nov 27 02:38:49 2000
> > Date: Sun, 26 Nov 2000 18:00:45 +0100
> > From: Andreas Lange <Andreas.Lange at Rhein-Main.de>
> > To: GRASS <grass at geni.knu.ac.kr>
> > CC: grass5 at geog.uni-hannover.de
> > Subject: Re: [GRASS5] some bugs
> > Hi Huidae,
> > thanks a lot for your answer.
> > GRASS wrote:
> > > > - with d.pan and d.zoom the color of vectors is always restored white.
> > > > If you draw a map with a e. g. green vector and zoom/pan, the vector is
> > > > re-drawn, but always white instead of the initial green.
> > > > There must be something wrong with the R_pad contents, as d.save puts
> > > > out the correct color with the vector before calling d.zoom/d.pan, but
> > > > afterwards the color is white even in the pad structure, so that d.save
> > > > puts out "d.vect vect=vect at PERMANENT color=white".
> > > That's not bug. It is intended behaviour.
> > > If you want to recreate current window using d.zoom, use -r flag.
> > OK, the -r flag is not shown in the tcltkgrass module and in the
> > html-manpage. So i overlooked that.
> > But i still think that it is a bug (or at least an inconsitency) that
> > the window is redrawn with d.zoom/d.pan, but the color of the vector is
> > changed to white. I think that d.zoom/d.pan should either always redraw
> > the correct screen or don't redraw anything at all without the -r flag.
> > In that case the user can first use d.save, then d.zoom/d.pan and then
> > redraw the screen without waiting for the "wrong" redraw of
> > d.zoom/d.pan.
> > Just how i would like it.
> Now implemented what you want.
> > > d.pan is not implemented to recreate window, -r flag.
> > It would be nice if d.zoom and d.pan behave identically, otherwise it is
> > confusing.
> Absolutely you're right.
> d.pan has some old code to be updated as soon as possible.
d.zoom code is merged into d.pan. So d.pan and d.zoom behave identically.
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
