[GRASS5] Re: some bugs
grass at geni.knu.ac.kr
Sun Nov 26 11:58:01 EST 2000
From: Andreas Lange <Andreas.Lange at Rhein-Main.de>
> Hi,
> just to report some minor bugs:
> - g.mlist does not work on IRIX.
> It just puts out a long listing of fragments of the shell script itself.
> Had no time to look into that.
It's strange.. There is no code to do that.
> - with d.pan and d.zoom the color of vectors is always restored white.
> If you draw a map with a e. g. green vector and zoom/pan, the vector is
> re-drawn, but always white instead of the initial green.
> There must be something wrong with the R_pad contents, as d.save puts
> out the correct color with the vector before calling d.zoom/d.pan, but
> afterwards the color is white even in the pad structure, so that d.save
> puts out "d.vect vect=vect at PERMANENT color=white".
Now default behaviour is to use correct colors. -j flag is used to redraw
maps using command's default color.
Yours,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
