[GRASS5] Re: bug in configure routine
Markus Neteler neteler at geog.uni-hannover.de
Sat Nov 25 13:45:21 EST 2000
Hi again,
On Fri, Nov 24, 2000 at 09:01:58PM +0100, Andreas Lange wrote:
> Hi,
> just some comments on comments:
> > > Module source code not installed: html (ignored)
> depends on perl in /usr/bin/perl.
> Compiles on Cygwin after creating a link from /usr/local/bin/perl to
> /usr/bin/perl.
> IRIX: if perl is installed, create the link. I remember perl is perl4 on
> older IRIX systems, perhaps will not work with newer scripts.
Perhaps an issue for "configure.in": find the PERL location?!
[useful comments removed]
> > > Module source code not installed: src/raster/r.out.png (ignored)
> Still needs the netpbm-headers, which are _not_ included in the binary
> distributions for Windows and IRIX. Had this problem too, copied over
> the headers from my linux machine.
> Markus, i'll send you a tarball of the header files. Please check if
> there are licensing issues when putting this on the server.
O.k.
> > > Module source code not installed: src.contrib/UCB/gdbase (ignored)
> > I have fixed the Gmakefile.
> > compiles on Linux *now*
> Is this part of the GRASS list?
It was because of s.reclass which is in src/scripts/.. now. I have commented
it now in src/CMD/lists/GRASS.
Thanks for your comments, Andreas,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
