[GRASS5] Win32 compile with cygnus ...
Mike Thomas mthomas at gil.com.au
Thu Nov 23 15:57:46 EST 2000
> ash should be 100% Bourne Shell compatible.  If bash.exe makes the
> problem go away, then there must be a "bash-ism" that needs to be
> changed.
Could be the underlying Cygwin system too.
> > Unfortunately the entire OS crashes not long after starting now!
> That's no good.
But unfortunately typical!  They recently released a new version of GCC, so
that may be the trouble.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
