[GRASS5] Win32 compile with cygnus ...
Eric G . Miller
egm2 at jps.net
Thu Nov 23 15:38:59 EST 2000
On Fri, Nov 24, 2000 at 06:37:40AM +1000, Mike Thomas wrote:
> Hi guys.
> I found the problem. I swapped the Cygwin sh.exe (by default they use
> ash.exe) to bash.exe and the problem went away.
ash should be 100% Bourne Shell compatible. If bash.exe makes the
problem go away, then there must be a "bash-ism" that needs to be
changed.
> Unfortunately the entire OS crashes not long after starting now!
That's no good.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
