[GRASS5] GRASS module descriptions (3)
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 23 13:29:11 EST 2000
"Eric G . Miller" wrote:
> On Thu, Nov 23, 2000 at 09:56:02AM +0000, Markus Neteler wrote:
> > unchanged:
> > r.out.bil/r.out.bil2: shall we keep this? Probably update the new
> > r.out.bin?
> Does the new r.in.bin handle bil files (Band interleaved by line)?
> There could be multiple image band in these types of files. Does gdal
> support them? As long as something does...
Eric,
GDAL supports a few forms of raw binary labelled files. The most general
is likely the "PCI .aux labelled". For this type, you write a .aux file
header for your data. The format is described at:
http://www.pcigeomatics.com/cgi-bin/pcihlp/GDB|Supported+File+Formats|Raw+Binary+Image+Format+(RAW)|Raw+.aux+Format
For instance, the following would described a binary file called test.raw
that is 300x300 with 2 bands, interleaved by line.
AuxilaryTarget: test.raw
RawDefinition: 300 300 2
ChanDefinition-1: 16U 0 2 1200 Swapped
ChanDefinition-2: 16U 600 2 1200 Swapped
The chan definition fields are:
type: ie. 8U, 16U, 16S or 32R
offset to first pixel: in bytes
offset between pixels: in bytes
offset between scanlines: in bytes
byte order flag: Swapped for LSB (intel), or Unswapped for MSB (sun)
Best regards,
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
