[GRASS5] GRASS module descriptions (3)
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 23 11:34:21 EST 2000
On Thu, Nov 23, 2000 at 12:08:49AM +0100, Andreas Lange wrote:
> Hi Michel, Hi Jan-Oliver,
> Michel Wurtz wrote:
> > I run a "simple" script to show what's happening (see below)
> > and found the following infos :
> > d.colors, d.pan, d.save, d.what.sites, d.zoom,
> > Thoses commands give only the text help when a monitor is running
> > Without a running monitor, they print the following error message :
> > No graphics monitor has been selected for output.
> > Please run "d.mon" to select a graphics monitor.
> I noticed this when implementing the testsuite. But i have no obvious
> solution.
Would it make sense to put the monitor test after parsing the command
line and checking, if "-help" was given (and how to implement that)?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
