[GRASS5] r.in.png/r.out.png
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed Nov 22 18:28:36 EST 2000
Hi Eric,
thanks for the hint. I'll look into that another time and update the
code of r.in.png and r.out.png.
The pnm.h header includes internally half a dozen other header files,
and in one older version one header that is incompatible with some
Cygwin header.
But i can compile r.in.png and r.out.png now on Linux, IRIX and
Cygnus/Win32.
As a side note: GDAL supports non-georeferenced image formats (jpeg,
png) too, so that i think we should standardize on GDAL in the long
term. The complicated part with image import is IMHO not reading/writing
the image, but the color support for GRASS. And that is not appropriate
with r.in.png/r.out.png.
cu,
Andreas
Eric G . Miller wrote:
> Haven't looked myself, but does the code specify a compression level
> and/or bit packing for the png_lib?  Deflate compression (zlib) should
> be built in and only needs to be specified at the beginning with a call
> like:
>         png_set_compression_level (png_ptr, Z_DEFAULT_COMPRESSION);
> I just gleaned this from the libpng.txt file that came with the library
> (I'd hardly claim to be an expert).
> I'll be adding zlib.h/libz checks to the configure script and it will
> define HAVE_ZLIB_H in src/include/config.h.  Actually, I already did
> this and then found how the configure script has things *not* in
> configure.in (Oooh, bad).  Ahh, I see zlib.h is already included in png.h.
> Still, configure should check.
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
