[GRASS5] MacOS X binaries dependencies
Justin Hickey
jhickey at hpcc.nectec.or.th
Thu Nov 23 02:43:01 EST 2000
Hi Jeshua
Jeshua Lacock wrote:
> > > Sorry, </usr/local/grass-5.0b/dev/fifo.1a> not available
> > > Have GRASS administrator check etc/monitorcap file
> > > What other files might tcltkgrass may be dependent on??
> > Hmmm. Did you use the installation script grass5install.sh? This
> > script is supposed to create the fifos.
> Yessir! Uh-oh!
In that case, please do an ls -Fla in the directory
It should look something like this:
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.17b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1b|
If they do look like this, then compare the directory paths in
etc/monitorcap with /usr/local/grass-5.0b/dev/. They should be the same.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
