[GRASS5] MacOS X binaries dependencies
Jeshua Lacock
jeshua at SierraMaps.com
Thu Nov 23 02:56:42 EST 2000
On Wednesday, November 22, 2000, at 11:43 PM, Justin Hickey wrote:
> > > > Sorry, </usr/local/grass-5.0b/dev/fifo.1a> not available
> > > > Have GRASS administrator check etc/monitorcap file
> > > > What other files might tcltkgrass may be dependent on??
> > > Hmmm. Did you use the installation script grass5install.sh? This
> > > script is supposed to create the fifos.
> > Yessir! Uh-oh!
> In that case, please do an ls -Fla in the directory
> It should look something like this:
> prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.17b|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18a|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18b|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19a|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19b|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1a|
> prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1b|
> If they do look like this, then compare the directory paths in
> etc/monitorcap with /usr/local/grass-5.0b/dev/. They should be the same.
Thanks Justin! It turns out that (for whatever reason) grass was installed at /usr/local/grass5.
I made a symbolic link /usr/local/grass-5.0b -> /usr/local/grass5 and it works!!
(Markus: can you please add this to the installation instructions?: cd /usr/local; ln -s grass-5.0b grass5;)
Cheers,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
