[GRASS5] Release GRASS5.0stable_pre1 ?
Jeshua Lacock
jeshua at SierraMaps.com
Mon Nov 20 05:12:36 EST 2000
On Monday, November 20, 2000, at 01:53 AM, Justin Hickey wrote:
> Jeshua Lacock wrote:
> > Will I have to recompile beta 8?
> Not necessarily. You can trick the Makefile into making the
> grass5install.sh script without compiling the source (I think). Try the
> following:
> In your Makefile, go to the bindist target and comment out all lines for
> that target except the one that starts with
> ${SHELL} -c "sed -e \"s/BIN_DIST_VERSION/...........
> It is the really long line for the bindist target. Save the file and
> then do a "make bindist" which should produce the grass5install.sh file.
> Don't forget to un-comment the lines again once you have the
Thanks Jazzman!
(by the way sorry for the name of this thread)
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
