[GRASS5] Win32 compile with cygnus
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Nov 20 03:13:49 EST 2000
Andreas Lange wrote:
> Eric G . Miller wrote:
> > > > For the float.h: does this introduce problems on other systems?
> > > > maybe a #ifdef __CYGWIN__ would be better.
> > > I don't think this ifdef is required. I had to add it to r.in.dem
> > > as well (for MacOS). The Linux likes it, too. It's present on
> > > SUN/Solaris. On CRAY it is o.k., too. What about SGI?
> > What's the problem with float.h? I know I've used it in a couple
> > places for DBL_MIN, DBL_MAX and friends (not in limits.h). I
> > thought this was a standard header ???
Yes, it is a standard header, since it appears in the standard library
listed in Appendix B of "The C Programming Language" by Kernighan and
Ritchie. There should be no problems using it.
> We discussed this some time ago on this list. But i can't memorize the
> result. I faintly remember problems with the BSD flavours. There must
> be a reason why Huidae Cho didn't include float.h i assume.
I don't recall this discussion, can anyone remember what the problem
was? Is BSD using a non-standard float.h file?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
