[GRASS5] Win32 compile with cygnus
Eric G . Miller
egm2 at jps.net
Sun Nov 19 14:50:08 EST 2000
On Sun, Nov 19, 2000 at 08:05:59PM +0000, Markus Neteler wrote:
> > I personally think that we shouldn't waste time on re-writing
> > r.in.png/r.out.png to remove the dependency on this library, but look
> > for a more generic solution for the import of non-georeferenced images.
> > I'll check in some thoughts of mine in the next days. I think we should
> > look for a general library that handles the usual image formats (png,
> > jpeg, etc.).
> Yes, that would be the best. Probably the GDAL could help here.
I'd think netpbm is pretty portable. But I could be wrong.
> > For the float.h: does this introduce problems on other systems?
> > maybe a #ifdef __CYGWIN__ would be better.
> I don't think this ifdef is required. I had to add it to r.in.dem as
> well (for MacOS). The Linux likes it, too. It's present on SUN/Solaris.
> On CRAY it is o.k., too. What about SGI?
What's the problem with float.h? I know I've used it in a couple places
for DBL_MIN, DBL_MAX and friends (not in limits.h). I thought this was
a standard header ???
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
