[GRASS5] Win32 compile with cygnus
Andreas Lange
Andreas.Lange at Rhein-Main.de
Sun Nov 19 14:18:21 EST 2000
Hi Markus,
your are much too fast for me ;-). I want to first check any changes on
Linux and with the cygnus setup, but re-compiling with cygnus needs
several hours. Now i know what John Huddleston is talking about.
depend on the netpbm library. This is always installed on Linux and most
other Unix. I never tested if this library compiles under Cygwin. I'll
add this dependency to the REQUIREMENTS file.
I personally think that we shouldn't waste time on re-writing
r.in.png/r.out.png to remove the dependency on this library, but look
for a more generic solution for the import of non-georeferenced images.
I'll check in some thoughts of mine in the next days. I think we should
look for a general library that handles the usual image formats (png,
jpeg, etc.).
For the float.h: does this introduce problems on other systems?
maybe a #ifdef __CYGWIN__ would be better.
For g.html2man:
Another solution would be to maintain the man-pages on the server and to
automatically update them there and check them in. I have no idea if
this is possible or better.
Converting the perl script to a sed/shell script is possible, but this
would hurt performance (we had this situation already!).
Does anybody know if there is a tcl/tk X11 wish with the Cygwin port of
X11R6? If not, i see not how tcltkgrass will work in the cygwin port.
cu,
Andreas
Markus Neteler wrote:
> Hi Andreas,
> thanks for testing GRASS on Cygwin!
> Here some comments:
> On Sun, Nov 19, 2000 at 06:10:16PM +0100, Andreas Lange wrote:
> > Compilation error in module: html (ignored)
> > - perl missing
> -> Hi Michel, hi all, is anybody willing to change g.html2man from
> PERL to shell script? It's the only PERL dependency, as far as I know.
> > Compilation error in module: src/raster/r.agnps50 (ignored)
> > - missing $(XDRLIB) in r.cn/Gmakefile
> Fixed.
> > - sys/config.h permission denied ???
> ?? Looking at the #include statements, it looking normal.
> > Compilation error in module: src/raster/r.in.gdal (ignored)
> > - gbgetsymbol.c:111: redefinition of GBGetSymbol
> Hi Frank W. :-)
> > Compilation error in module: src/raster/r.in.png (ignored)
> > - pnm.h not found in pgnfunc.h
> > - libpng only knows png.h and pngconf.h ?
> It seems to require the "netpbm" lib.
> I have it here:
> /usr/X11R6/include/pnm.h
> It would be good to remove the netpbm dependency (TODO).
> > Compilation error in module: src/raster/r.out.png (ignored)
> > - pnm.h, ppm.h missing
> see r.in.png comment
> > Compilation error in module: src/raster/r.random (ignored)
> > FLT_MAX, FLT_MIN, DBL_MIN undeclared
> I have added
> #include <float.h>
> into count.c. Please try again.
> > Compilation error in module: src/sites/s.windavg (ignored)
> > - missing xdr lib in Gmakefile
> fixed.
> > Compilation error in module: src.contrib/CERL/raster/r.linear.regression (ignored)
> > - solve.c:14: multiple definition of solve
> I have renamed solve to solve2 in nlfit.c
> Please try again.
> > Compilation error in module: src.contrib/CERL/raster/r.rational.regression (ignored)
> > - nlfit.c: ... multiple definition of solve
> Please try again.
> Hope this help a bit
> Markus
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
