[GRASS5] New MacOS X compilation errors
Markus Neteler
neteler at geog.uni-hannover.de
Sun Nov 19 13:56:11 EST 2000
Hi all,
On Sat, Nov 18, 2000 at 06:39:51PM -0800, Jeshua Lacock wrote:
> The XDRIVER24 module fails to compile because the module is dependent on the switcher.c that also fails to compile. Here's the log:
> SWITCHER.c: In function `xalloc':
> SWITCHER.c:1369: conflicting types for `malloc'
> /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:121: previous declaration of `malloc'
> SWITCHER.c:1369: warning: extern declaration of `malloc' doesn't match global one
> SWITCHER.c:1369: conflicting types for `realloc'
> /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:125: previous declaration of `realloc'
> SWITCHER.c:1369: warning: extern declaration of `realloc' doesn't match global one
> make[2]: *** [OBJ.powerpc-apple-darwin1.2/SWITCHER.o] Error 1
> make[1]: *** [all] Error 2
> Any ideas?
Jeshua, could you try to replace all "malloc" with "G_malloc"?
If o.k., we should check the entire CVS for malloc. I recently
changed r.flow on that, seems to work o.k.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
