[GRASS5] Win32 compile with cygnus
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Nov 19 12:10:16 EST 2000
here now the commented error.log of my first attempt to compile on
Win32.
That looks quite good, only some minor problems. Currently i have not
installed the X libraries, i expect to arrive a complete compiler/tools
CD next week.
Any idea what the problem with the fonts is?
I'll try to fix the other problems, if someone knows an apparent
solution, please tell me so that i don't waste time on something that
has a known solution.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
GRASS GIS compilation log
Start of compilation: Sun Nov 19 14:55:56  2000
Errors:
Compilation error in module: html (ignored)
- perl missing
Compilation error in module: src/display/devices/XDRIVER (ignored)
- ok, no xlibraries, no ipc configure
Compilation error in module: src/fonts/for_grass (ignored)
- can't red index!
Compilation error in module: src/raster/r.agnps50 (ignored)
- missing $(XDRLIB) in r.cn/Gmakefile
- sys/config.h permission denied ???
Compilation error in module: src/raster/r.in.gdal (ignored)
- gbgetsymbol.c:111: redefinition of GBGetSymbol
Compilation error in module: src/raster/r.in.png (ignored)
- pnm.h not found in pgnfunc.h
- libpng only knows png.h and pngconf.h ?
Compilation error in module: src/raster/r.mapcalc (ignored)
- ok. lokal problem with permissions on *.y files while mounting CVS tree
- yacc not found: should call bison instead!!!!!!!!
Compilation error in module: src/raster/r.out.png (ignored)
- pnm.h, ppm.h missing
Compilation error in module: src/raster/r.random (ignored)
FLT_MAX, FLT_MIN, DBL_MIN undeclared
Compilation error in module: src/sites/s.windavg (ignored)
- missing xdr lib in Gmakefile
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
- ok. can not compile,
Compilation error in module: src.contrib/CERL/raster/r.linear.regression (ignored)
- solve.c:14: multiple definition of solve
Compilation error in module: src.contrib/CERL/raster/r.rational.regression (ignored)
- nlfit.c: ... multiple definition of solve
End of compilation:   Sun Nov 19 16:48:41  2000
DONE generating GRASS GIS binary code
