[GRASS5] New IPC XDRIVER vs. fifo vs. UNIX Sockets???
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Nov 19 07:52:50 EST 2000
Hi Eric,
sorry, i simply don't know. A loadable module would do, but would
require reorganizing the whole tcltkgrass code.
tcl/tk can under win32 only be recompiled with the MS compiler if it
should use the Win32 API for graphics windows.
But if you install X11R6.4 under the cygwin setup it should be possible
to recompile a wish for X11 graphics windowing.
But i have no practical expirience with Cygwin.
cu,
Andreas
Eric Mitchell wrote:
> > But compiling a tk8.x wish shell under Windows requires a MS compiler.
> Do you need to compile a full customized wish shell? Or would a
> dynamically loadable module work?  And is that possible with Cygwin?
> -- ebm
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
