[GRASS5] Win32 configure.
Andreas Lange
Andreas.Lange at Rhein-Main.de
Sun Nov 19 08:48:23 EST 2000
Hi Mike,
i'll check in the XDR part.
Will this suffice? I had the problem that the sunrpc packet is installed
under /usr/local/{include|lib} instead of /usr/{include|lib}.
For the headers: I think that you should leave the headers and libraries
as installed and edit manually the src/CMD/head/head.* file unless this
is implemented correctly with configure.
cu,
Andreas
Mike Thomas wrote:
> Hi all.
> One of the problems with building on Windows is that the configure script
> doesn't work well.
> Q 1.
> By inspecting configure.in, I notice that a check should be done for rpclib
> in the XDR part as follows:
> XDRLIB=
> if test -z "${XDRLIB}"; then
> AC_CHECK_LIB(sun, xdr_int, XDRLIB=-lsun)
> fi
> AC_CHECK_LIB(nsl, xdr_int, XDRLIB=-lnsl)
> fi
> AC_CHECK_LIB(rpclib, xdr_int, XDRLIB=-lrpclib)
> fi
> AC_SUBST(XDRLIB)
> As I haven't been able to get autoconf to work on my computer, could someone
> please do this and check it in?
> Q 2.
> Also, I happen to keep my X headers and libraries in /usr/local/X11r6.4
> which doesn't get picked up by configure. Maybe what I really need to do is
> move them elsewhere rather than expecting configure to do this.
> Is there a recommended location to put them on Windows?
> Cheers
> Mike Thomas.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
