[GRASS5] Re: TclTkGrass: default directory
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 16 11:07:36 EST 2000
Hi Eric,
maybe you did not get the mail due to the server problems here
last night: Justin already fixed this bug. Now it's opening
the directory where tcltkgrass was started.
Regards
Markus
On Thu, Nov 16, 2000 at 10:15:52AM -0500, Eric Mitchell wrote:
> maybe $LOCATION would be appropriate?
> Markus Neteler wrote:
> > On Wed, Nov 15, 2000 at 08:29:30PM +0100, Andreas Lange wrote:
> > > Markus,
> > > is it ok if the home directory is used?
> > > This would require that the enviroment variable HOME is set.
> > > Everything else (how do you define the 'current' directory? The one you
> > > are in at startup of tcltkgrass?) would be complicated.
> > This would be perfect. I think it was working like that in
> > past. Since Moritz comment I am aware that it is not the
> > tcltkgrass startup directory any more.
> > But HOME is o.k., better than /usr/games :-)
> > Thanks for loking into that,
> -- ebm
> | Eric B. Mitchell mailto:emitchell at altaira.com |
> | tel: (301) 809 - 3534 Altair Aerospace Corporation |
> | tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
> | fax: (301) 805 - 8122 Bowie, MD 20716 |
> ,___
> /"\ / o=\ /"""---===/
> / \_/ \__/ ---===/
> | //\ || /""TT""/ //\ || ||""\
> | // \ || || // \ || ||__/
> | //--==\ |L--/ || //--==\ || || "=,
> \____---===/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
