[GRASS5] Re: TclTkGrass: default directory
Eric Mitchell
emitchell at altaira.com
Thu Nov 16 10:15:52 EST 2000
maybe $LOCATION would be appropriate?
Markus Neteler wrote:
> On Wed, Nov 15, 2000 at 08:29:30PM +0100, Andreas Lange wrote:
> > Markus,
> > is it ok if the home directory is used?
> > This would require that the enviroment variable HOME is set.
> > Everything else (how do you define the 'current' directory? The one you
> > are in at startup of tcltkgrass?) would be complicated.
> This would be perfect. I think it was working like that in
> past. Since Moritz comment I am aware that it is not the
> tcltkgrass startup directory any more.
> But HOME is o.k., better than /usr/games :-)
> Thanks for loking into that,
-- ebm
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
