[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update:
grass/src/raster/r.binfer
Markus Neteler
neteler at geog.uni-hannover.de
Wed Nov 15 16:09:47 EST 2000
On Wed, Nov 15, 2000 at 08:09:40PM +0000, David D Gray wrote:
> > > Author: david
> > > Update of /grassrepository/grass/src/raster/r.binfer
> > > In directory intevation.de:/tmp/cvs-serv18425
> > > Modified Files:
> > > binfer.l
> > > Log Message:
> > > Changed to elliminate `dangerous trailing context' warning: caused parse
> > > failure (in binfer.y) on linux-i386 at least
> > On cray I get:
> > /home/t3e/fsn/nhdc/nhdcmark/grass/src/raster/r.binfer
> > make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
> > rm -f lex.c gram.c
> > yacc binfer.y
> > rm -f gram.c
> > mv y.tab.c gram.c
> > cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c gram.c
> > -o OBJ.alpha-cray-unicosmk2.0.4.X/gram.o
> > lex binfer.l
> > "binfer.l":line 13: Error: Missing translation value
> > Make: "lex binfer.l": Error code 1
> > But it is lex there, not flex:
> > lex - Generates programs for simple lexical tasks
> > STANDARDS
> > POSIX, XPG4
> > well, let's ignore CRAY...
> > Thanks for updating
> > Markus
> Hi Markus
> Do you know exactly what lex Cray uses? The problem seems to be the
> %option statement. So perhaps we could get round that by putting in
> conditional code, as Cray presumably doesn't need the lex-compat
> statement. Do you [anyone] know off-hand the definition code for Cray?
Hi David,
how can I find out?
man lex
LEX(1) UNICOS/mk 2.0.4 Last changed: 2-24-98
NAME
SYNOPSIS
lex [-t] [-r] [-n] [files]
lex [-t] [-r] [-v] [files]
Obsolescent version; may not be supported in future releases:
lex -c [-t] [-r] [-n] [files]
lex -c [-t] [-r] [-v] [files]
IMPLEMENTATION
CRAY T3E systems
STANDARDS
POSIX, XPG4
AT&T extensions (-r option)
SEE ALSO
yacc(1)
lex & yacc, Doug Brown and Tony Mason, O'Reilly & Associates, Inc.,
1992.
The UNIX Programming Environment, Brian W. Kernighan and Rob Pike,
Prentice-Hall, Inc., 1984.
UNICOS/mk User Commands Reference Manual, publication SR-2611, for the
printed version of this man page.
Is there anything else I could try?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
