[GRASS5] Re: TclTkGrass: default directory
Markus Neteler neteler at geog.uni-hannover.de
Wed Nov 15 15:00:20 EST 2000
On Wed, Nov 15, 2000 at 08:29:30PM +0100, Andreas Lange wrote:
> Markus,
> is it ok if the home directory is used?
> This would require that the enviroment variable HOME is set.
> Everything else (how do you define the 'current' directory? The one you
> are in at startup of tcltkgrass?) would be complicated.
This would be perfect. I think it was working like that in
past. Since Moritz comment I am aware that it is not the
tcltkgrass startup directory any more.
But HOME is o.k., better than /usr/games :-)
Thanks for loking into that,
 Markus
> cu,
> Andreas
> Markus Neteler wrote:
> > On Wed, Nov 15, 2000 at 02:24:34PM +0100, mlennert at club.worldonline.be wrote:
> > > Hello,
> > > How can I change the default directory to which the 'file' buttons open the
> > > file browser ? Right now it always opens to /usr/games...
> > Hi all,
> > does anybody has an idea? If you use in tcltkgrass:
> > Import-> Raster map -> something
> > and hit the file button, it is not the current
> > directory (but it should).
> > For Moritz it is /usr/games, on my machine /usr/openwin/bin.
> > Must be a problem in src/tcltkgrass/main/gui.tcl
> > Thanks in advance
> >  Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
