[GRASS5] Re: TclTkGrass: default directory
Andreas Lange
Andreas.Lange at Rhein-Main.de
Wed Nov 15 14:29:30 EST 2000
Markus,
is it ok if the home directory is used?
This would require that the enviroment variable HOME is set.
Everything else (how do you define the 'current' directory? The one you
are in at startup of tcltkgrass?) would be complicated.
cu,
Andreas
Markus Neteler wrote:
> On Wed, Nov 15, 2000 at 02:24:34PM +0100, mlennert at club.worldonline.be wrote:
> > Hello,
> > How can I change the default directory to which the 'file' buttons open the
> > file browser ? Right now it always opens to /usr/games...
> Hi all,
> does anybody has an idea? If you use in tcltkgrass:
> Import-> Raster map -> something
> and hit the file button, it is not the current
> directory (but it should).
> For Moritz it is /usr/games, on my machine /usr/openwin/bin.
> Must be a problem in src/tcltkgrass/main/gui.tcl
> Thanks in advance
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
