[GRASS5] Mac OS X r.* errors
System Administrator
jeshua at SierraMaps.com
Wed Nov 15 03:59:43 EST 2000
On Tuesday, November 14, 2000, at 09:48 PM, Eric G . Miller wrote:
> Do exactly what it says and retry (that is, run "ranlib" on your
> libtiff.a, then cd to <grass>/src/raster/r.tiff and run "gmake5").
Thanks Eric! It's compiled now thanks to you.
> > __________________________________________________________
> > GISGEN: src/raster/r.in.png - Tue Nov 14 16:12:52 PST 2000
> > /usr/src/grass/src/raster/r.in.png mkdir OBJ.powerpc-apple-nextstep3
> > make -f OBJ.powerpc-apple-nextstep3/make.rules
> > rm -f OBJ.powerpc-apple-nextstep3/r.in.png.o cc -g -O2
> > -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include
> > -I/usr/include -I/usr/src/grass/src/include -c r.in.png.c GISGEN
> > failure at STEP: src/raster/r.in.png
> Try changing into the <grass>/src/raster/r.in.png/ dir and running
> "gmake5". It might produce more informative output.
Excellent, thanks! Both r.in.png and r.out.png appear to be dependent on the missing 'pnm.h' header (I searched my system to no avail):
pngfunc.h:11: header file 'pnm.h' not found
pngfunc.h:27: undefined type, found `xel'
r.in.png.c:178: undefined type, found `pixel'
r.in.png.c:181: undefined type, found `pixel'
r.in.png.c:188: undefined type, found `pixel'
make[1]: *** [OBJ.powerpc-apple-nextstep3/r.in.png.o] Error 1
make: *** [all] Error 1
The r.in.dem is dependent on the missing library 'values.h': dem_read.c:4: header file 'values.h' not found
The r.flowmd is dependent on the missing library 'malloc.h'
The r.binfer module faild to compile because "binfer.l:46: redefinition of `yylineno'", so I edited "binfer.l", renamed all (two) instances of yylineno with yylineno2, and it compiled (possible bug?).
That's all for now...
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
