[GRASS5] Mac OS X r.* errors
Eric G . Miller
egm2 at jps.net
Wed Nov 15 00:48:50 EST 2000
On Tue, Nov 14, 2000 at 08:44:06PM -0800, System Administrator wrote:
> Greetings,
> Note that I am unable to open files in GIF format. If I click on the
> 'RUN' module it states that "Couldn't execute 'r.in.gif': no such file
> or directory". Sure enough, the module is not to be found. Upon
> inspection of the install logs, I do not see any gif modules that were
> compiled - ignored or successful. There is a r.in.gif file in the
> src/raster directory.
Removed due to LZW patent. Should not be in TclTk menus (BUG).
> The PNG module does not state any useful error messages, however the
> TFF module does.
> Here is the log output for the TIFF module, followed by the PNG
> module.
> /usr/src/grass/src/raster/r.tiff mkdir OBJ.powerpc-apple-nextstep3
> make -f OBJ.powerpc-apple-nextstep3/make.rules
> rm -f OBJ.powerpc-apple-nextstep3/r.in.tiff.o cc -g -O2
> -I/usr/src/grass/src/include -c r.in.tiff.c mv r.in.tiff.o
> OBJ.powerpc-apple-nextstep3/r.in.tiff.o cc -o
> /usr/local/grass-5.0b/etc/bin/contrib/cmd/r.in.tiff
> /usr/src/grass/src/libes/LIB.powerpc-apple-nextste p3/libgis.a
> -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib -ltiff -lz /usr/bin/ld:
> table of contents for archive: /usr/local/lib/libtiff.a is out of
> date; rerun ranlib(1) (can't load from it) GISGEN failure at STEP:
> src/raster/r.tiff
Do exactly what it says and retry (that is, run "ranlib" on your
libtiff.a, then cd to <grass>/src/raster/r.tiff and run "gmake5").
> __________________________________________________________
> GISGEN: src/raster/r.in.png - Tue Nov 14 16:12:52 PST 2000
> /usr/src/grass/src/raster/r.in.png mkdir OBJ.powerpc-apple-nextstep3
> rm -f OBJ.powerpc-apple-nextstep3/r.in.png.o cc -g -O2
> -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include
> -I/usr/include -I/usr/src/grass/src/include -c r.in.png.c GISGEN
> failure at STEP: src/raster/r.in.png
Try changing into the <grass>/src/raster/r.in.png/ dir and running
"gmake5". It might produce more informative output.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
