[GRASS5] Re: [GRASSLIST:1116] compiling postgres modules (fwd)
mlennert at club.worldonline.be mlennert at club.worldonline.be
Tue Nov 14 08:11:03 EST 2000
> Hi Moritz
> On Tue, Nov 14, 2000 at 11:27:15AM +0100, mlennert at club.worldonline.be wrote:
> > > I'll try that. Is there any way of finding out if  I checked out a
> > > tagged tree? I don't think so, but wouldn't swear on it.
> If you go into grass/ and update with
> cvs update -dP
> you get the latest code.
That's what I did before, but the files didn't change, and I do not have any
memory of having tagged a version. (I followed the instruction on the GRASS
cvs web page to create my private copy, i.e. cvs -z3 co grass). Now I've
downloaded the entire tree again, and the files are the correct ones. I guess
it must have been a local problem...
> If you want a tagged version, open a new directory and
> check it out:
> cvs -z3 co -r "release_grass5beta8_26_july_2000" grass
> > > Justin when I type 'cvs update -PdA grass I get:
> > > cvs update: cannot open CVS/Entries for reading: No such file or
> > > directory
> > > cvs [update aborted]: no repository
> > > I don't get this message when I leave out 'grass'. Is this a problem ?
> I update *within* grass directory and *without* grass-parameter
> (see above). That works well for me.
> Regards
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
