[GRASS5] Re: [GRASSLIST:1116] compiling postgres modules
mlennert at club.worldonline.be mlennert at club.worldonline.be
Tue Nov 14 08:24:23 EST 2000
> Hi Moritz,
> On Tue, Nov 14, 2000 at 10:33:24AM +0100, mlennert at club.worldonline.be wrote:
> > I have the feeling there is a problem with my cvs. I've update through cvs
> > update -dP, but the Makefile and the configure file had not been updated. What
> > am I doing wrong ?
> The Makefile won't be updated as it is generated from Makefile.in.
> The configure might not be updated, if it is already up-to-date.
Sorry, I wasn't clear enough: I wanted to say Makefile.in.
And no, neither one of the two had been updated yesterday when I did a 'cvs
update -dP' in my grass cvs directory. Now I can't check anymore, since I've
erased everything and redownloaded it via 'cvs -z3 co grass' (I did need grass
for work...). Now the files are the correct ones. I guess we'll just have to
wait until the next updates to check wether the problem reoccurs.
> So, look for the Makefile.in timestamp.
> Hope this helps
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
