[GRASS5] Jan's copyright notice ++
Markus Neteler
neteler at geog.uni-hannover.de
Tue Nov 14 09:18:32 EST 2000
On Tue, Nov 14, 2000 at 11:13:53AM +0700, Justin Hickey wrote:
> Hello Frank.
> Frank Warmerdam wrote:
> > Given that we have significant divisions on the issue, I suggest we
> > drop the $Log$ part, and finalize the rest of the header prototype.
> OK. So the final header will be something like the following (I made up
> all the details for a file supposedly called colors.c):
> * $Id$
> * MODULE: d.rast (or new higher level module name (eg GRASS core)
> * for 5.1)
> * AUTHOR(S): Original author unknown - probably CERL
> * John Doe - jdoe at some.where.org
> * PURPOSE: To provide storage and manipulation of colors used for
> * rendering the raster. The colors are stored in a
> * doubly linked list which must be initialized with
> * InitColors() before it can be used. Note that most
> * linked list functionality (add, remove, get) is
> * supported, but their is no sorting functionality.
> * COPYRIGHT: (C) 2000 by the GRASS Development Team
> * This program is free software under the GPL (>=v2)
> * Read the file COPYING that comes with GRASS for details.
> Does anyone have objections to the above layout?
Hi Justin,
it looks nice! Perhaps you can add an empty "sheet" for easy copy-paste
to STYLE_PROGRAMMING.
> > Do you want to update the SUBMITTING file? Actually, I am surprised
> > this isn't in the STYLE_PROGRAMMING file.
> Yeah, you're right, STYLE_PROGRAMMING would be a better place for this.
> Does anyone object to moving this to STYLE_SUBMITTING?
These files should be merged. There is no reason to keep two separate
files.
Thanks in advance
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
