[GRASS5] Re: [GRASSLIST:1122] Re: monitor management unstable
mlennert at club.worldonline.be mlennert at club.worldonline.be
Mon Nov 13 12:38:30 EST 2000
> On Mon, Nov 13, 2000 at 06:10:46PM +0100, mlennert at club.worldonline.be wrote:
> > After compiling the CVS tree, the monitor management seems unstable on my
> > machine. TclTkGrass has actually crashed a few times, for example when I try
> > to stop a monitor. The connection to the monitors seem to break quite often,
> > and so I get "x0 is used by another user".  I actually think it might be a
> > problem in TclTkGrass since I haven't had this problem from the console. (I
> > was using d.what.vect when the problem appeared, but I've also had it after a
> > simple d.vect, d.rast suite).
> Hi Moritz,
> this is surprising as the monitor management is unchanged for month.
> We have recently included a preliminary IPC-support, but this is
> not used on default. So I guess it is a local problem (maybe new
> Xfree version or new windows manager?).
> Please: for discussions on CVS related stuff, please use the
> developer list (not to bother the "stable users").
> Thanks
>  Markus
Ok, here I am on the developer list. Sorry for hving bothered the main list,
but I did not consider myself a developer ;-)
I have recently switched to X11R6.4 (4.0.1-3), so that might be the problem.
Moritz
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
