[GRASS5] ps.map: -fwritable-strings
Markus Neteler
neteler at geog.uni-hannover.de
Mon Nov 13 12:53:23 EST 2000
On Mon, Nov 13, 2000 at 11:21:11AM -0500, Eric Mitchell wrote:
> When a bug gets fixed, that occurrence *must* be noted
> somehow, somewhere. Otherwise, you'll get developers trying
> to fix bugs more than once, and getting frustrated that the
> bug they're trying to track down is already fixed. I remember
> hearing a lot about a problem that required an extra compiler
> option (-fwritable-strings) on this very project. I went to
> investigate the matter only to discover no such problem existed.
> Had the bug fix been properly documented, I wouldn't have ever
> spent the time trying to fix it. This is also a step that only
> has to occur once.
Hi Eric, hi all,
I will send another mail on the bugtracking issue later.
Looking at your comment:
Is the -fwritable-strings bug gone? That's great. Then I will
remove this hint from
BUGS and
src/CMD/generic/POST_INSTALL.sh
Thanks
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
