[GRASS5] flex/lex, compatibility
Andreas Lange
Andreas.Lange at Rhein-Main.de
Mon Nov 6 14:49:25 EST 2000
Hi James,
you are correct, flex is not always installed. But without it you won't
be able to compile grass5 sources. That is what i wanted to say.
I know of no linux system with a non-GNU standard lex. Sometimes lex is
a shell script which calls flex -l (that is flex in lex compatibility
mode).
cu,
Andreas
James Cameron wrote:
> On Fri, Nov 03, 2000 at 07:25:55PM +0100, Andreas Lange wrote:
> > On Linux this causes no problems as flex is always installed
> Not so, it might not be installed. But if it is installed "lex" is a
> symbolic link to "flex". At least this is so on Red Hat and Debian
> GNU/Linux.
> James Cameron mailto:quozl at us.netrek.org http://quozl.netrek.org/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
