[GRASS5] Re: [GRASSLIST:1083] To deprecate m.in.pl94.db3 m.in.stf1.db3 m.in.stf1.tape?
Markus Neteler neteler at geog.uni-hannover.de
Mon Nov 6 04:22:29 EST 2000
Hi Malcolm,
On Sun, Nov 05, 2000 at 05:17:56PM -0600, Malcolm Williamson wrote:
> I can't speak about the first two, but m.in.stf1.tape is a basic filter
> that is essential to the use of v.in.tig.basic . It basically allows you
> to filter any ASCII file by a user-defined string, starting at a
> user-defined character position. See the GRASS TIGER tutorials. Perhaps
> is should be renamed, so that it's utility is more evident.
> 	-Malcolm Williamson
> 	 CAST - University of Arkansas
I consider to put the unused modules in a new section:
src/unused/
Then it's nmot lost but inactive.
For m.in.stf1.tape: Do you have a name suggestion?
Thanks in advance
 Markus
> Markus Neteler wrote:
> > Hi all,
> > for the code cleanup (GRASS 5 stable) I would like to know if
> > the modules:
> > are still in use. I am not familar with such U.S. specific
> > formats: Are these modules still up-to-date?
> > Thanks for your time
> >  Markus Neteler
> > Dipl.-Geogr. Markus Neteler *  University of Hannover
> > Institute of Physical Geography and Landscape Ecology
> > Schneiderberg 50 * D-30167 Hannover * Germany
> > Tel: ++49-(0)511-762-4494  Fax: -3984
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
