[GRASS5] Re: [GRASSLIST:1083] To deprecate m.in.pl94.db3
         m.in.stf1.db3 m.in.stf1.tape?
    Malcolm Williamson
    malcolm at cast.uark.edu
    Sun Nov  5 18:17:56 EST 2000
I can't speak about the first two, but m.in.stf1.tape is a basic filter
that is essential to the use of v.in.tig.basic . It basically allows you
to filter any ASCII file by a user-defined string, starting at a
user-defined character position. See the GRASS TIGER tutorials. Perhaps
is should be renamed, so that it's utility is more evident.
	-Malcolm Williamson
	 CAST - University of Arkansas
Markus Neteler wrote:
> Hi all,
> for the code cleanup (GRASS 5 stable) I would like to know if
> the modules:
> m.in.pl94.db3   m.in.stf1.db3   m.in.stf1.tape
> are still in use. I am not familar with such U.S. specific
> formats: Are these modules still up-to-date?
> Thanks for your time
>  Markus Neteler
> Dipl.-Geogr. Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
