[GRASS5] flex/lex, compatibility
Michel Wurtz
mw at teledetection.fr
Fri Nov 3 03:59:01 EST 2000
Andreas Lange a écrit :
> Hi,
> can we make flex a requirement for compiling of GRASS5?
> The problem is now that some modules can be compiled with either flex or
> lex, but one module uses an option "%option lex-compat" which is not
> recognized by standard lex.
> Under Linux everything is fine, as flex is always installed, but with
> Solaris and IRIX some machines have a standard, old-fashioned lex
> installed.
> Alternatively we could change the module/lex file, but this would
> require some investigation on the side-effects.
Can't this be done in ./configure ? detecting if there is a flex
command, or a lex command. On my linux box, lex is just a shell
script that call flex with the option "lex-compat". I think one
can do that at the Makefile level...
Michel WURTZ - DIG - Maison de la télédétection
500, rue J.F. Breton
34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
