[GRASS5] proposal for a grass command
interfacedescriptionforautomatic GUI building
Tim Cera
timcera at earthlink.net
Fri Oct 27 23:40:51 EDT 2000
Jan-Oliver Wagner wrote:
> > I think the command line interface should use the XML also. Instead of
> > having I/O commands hard coded in each command, a parser should be
> > called that would read the XML, collect user input, return appropriatly
> > set variables.
> The information on how a componenent works and what it needs is
> necessarily an integral part of the component itself.
> If you make the component load an external file with its
> interface description, it still needs to check whether
> it is compatible with its actual capabilities. You need
> error handling etc.
> To my mind the interface specification should be generated from
> the place where the interface is actually coded.
> Only this way overall consistency is guaranteed.
Good point. Could the command line interface still use the XML by
calling --interface-description? That sounds kinda messy ... ah
nevermind.
> For the language: I estimate that the GRASS community has
> the wish for say 10 languages. We have more than 400 commands
> so we need to manage and take care for over 4000 xml-files to have
> a consistent user interface.
> hm, possible, but I would like to have it more simple.
> We really should not mix languages and user interface descriptions.
That is why XML has such great advantages. There could be a XSL file
with a lot of the interface stuff, and XML with the text.
> Which advantages for users do you mean to gain by seperate user interface
> description files? Perhaps I am missing something. (I don't have learned
> about any facet of GRASS yet; its just a too mighty dragon ;-)
My day job is at an ESRI only shop and they have developed a whole suite
of local changes via Avenue, AMLs, ...etc. Say a GRASS admin wanted to
include some help with a particular command that is specific to that
organization. Just edit the XML. Not a huge advantage. The best
reason is still easy internationalization.
Something new. It would be nice to have a 'Help' button that is
described in the XML and will open up the man page. I sure can find
work for you! :-)
take care
tim
http://home.earthlink.net/~timcera
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
