[GRASS5] CELL->FP converting
Huidae Cho
hdcho at geni.knu.ac.kr
Thu Oct 26 14:43:20 EDT 2000
Hi developers,
Here are some efforts for easy converting CELL to FP.
Please check these sources and give me a hint :-)
This module simply shows raster map's values.
There are three functions and two data types.
is_null_value() can be used for CRAY instead of G_is_null_value().
value2str() is used to print values of various type of raster.
cpvalue() copies src[scol] to dest[dcol].
RASTER_PTR union may free us from complicated typecasting.
RASTER_MAP_PTR has raster map type and it's data.
Just try. :-)
Best Regards,
Huidae Cho
Name: not available
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001027/9d69bf18/attachment.obj
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001027/9d69bf18/attachment-0001.obj
