[GRASS5] testsuite with dejagnu
Eric Mitchell
emitchell at altaira.com
Tue Oct 24 10:28:55 EDT 2000
Markus Neteler wrote:
> > Another problem is that the make install process repeats the html to man
> > conversion every time it is invoked, there seems to be no status
> > information on the build process.
> Here we need something. Probably a timestamp comparison.
Make should do the comparison automatically. The trick is
in the proper setup of the rules to perform the conversion.
Something like the following:
# process the html pages into man pages
%.man: %.html
html2man $< > $@
# make sure the man directory exists
$(GRASS_MANDIR):
test -d $(GRASS_MANDIR) || mkdir -p $(GRASS_MANDIR)
# copy the man pages
$(GRASS_MANDIR)/%:% $(GRASS_MANDIR)
cp $< $@
The trick is in specifying the dependency of the man page
on the html page, and not just blindly executing the
html2man process.
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
