[GRASS5] r.to.sites: change proposal for -a
Markus Neteler
neteler at geog.uni-hannover.de
Tue Oct 24 10:30:33 EDT 2000
On Tue, Oct 24, 2000 at 08:38:04AM -0500, Bill Brown - staff wrote:
> >Hi all,
> >a proposal for r.to.sites:
> >Currently when converting raster data to sites format you
> >get a list like this:
> >3571556.25|5775981.25|#106
> >3571731.25|5775981.25|#123.8
> >3572243.75|5775981.25|#109.5
> >3570556.25|5775968.75|#132.5
> >Here we have two problems:
> > - #cat may be INT only
> > - usually you want %doubles format in sites list
> I didn't read all the earlier messages, but last I knew,
> cat can be any RASTER_MAP_TYPE. Did you change this?
Hi Bill,
I didn't change that, was just guessing (I should read the programmer's
manual). But I am expecting problems with s.surf.rst & friends if it is not
stored as %double. Or am I wrong?
The s.info only accepts INT cats:
s.info ktb12.5
Number of DIMENSIONS: 2
- - MIN - - - - MAX - -
dim 1 3558006.250000 3574281.250000 Easting
dim 2 5756006.250000 5775993.750000 Northing
Type of CATEGORY information: CELL_TYPE
80 370 No Label
although there are double cats. At least this is inconsistent
currently.
And if I want to reconvert the list back to raster with s.to.rast,
this module will make an INT raster map:
s.to.rast in=ktb12.5 out=test
Using size option: 0
Finding and opening site list...
ERROR: selected decimal field column no. 1 not present in sites list.
If interpolating, the s.surf.rst is also expecting doubles:
s.surf.rst help
input Name of the site file with input x|y|%z [%sm]
So it might be easier to modify the r.to.sites than all the other site
modules.
My 0.02 Euro...
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
