[GRASS5] small fixes
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed Oct 18 19:33:24 EDT 2000
Hi Eric,
thanks a lot for your tests. I must admit that i am clueless what the
library and the modules concerns. I did only change a define to avoid a
conflict with some BSD headers.
Maybe i will get back to s.geom and the library another time.
cu,
Andreas
Eric G . Miller wrote:
> Okay, well the "sweep" operation seems to be producing good results.
> None of the rest seem to function correctly (infinite lines,
> segmentation faults, other...).
> /bin/sh ~/.signature:
> Command not found
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
